Roaming
Azara786
I am in Ibiza until Monday and need my roaming abroad data roaming! They did not do this over phone when asked the other day they just have forgot
Christopher_G
Hi @Azara786
Have you tried manually connecting to an available network? Are you using a contract SIM or pay as you go?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
