21-10-2022
10:21 AM
- last edited on
21-10-2022
11:04 AM
DanielPA
Hi there, I forgot to activate my roaming before I traveled and now I’m here I can’t seem to be able to get through to anyone… I don’t like texting so could someone CALL me on xxxxxxxxxxx to sort this issue out! Please help me I’m struggling and I’m becoming desperate to communicate here as there is a wedding I’m attending tomorrow. Thanks Gavin.
[Mod edit: Please do not post personal information on the public board. Thanks!]
21-10-2022 11:28 AM - edited 21-10-2022 11:41 AM
Welcome to the community.
If you have a contract SIM, you should be able to activate roaming in your My EE account.
21-10-2022 11:32 AM
21-10-2022 11:41 AM
If your phone isn't set up for roaming, we won't be able to call you on it, @wilemangavin.
Is there someone with you who has a working UK phone?
21-10-2022 02:30 PM
@wilemangavin : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything.
