Roaming
CAHodson
We have been roaming France and Italy for two weeks now and despite buying the 'add on' and texting 'ROAMING' to 150 on several occasions We still cannot get phone, text or e:mail services. Our Google maps won't work --- we are paying for a service that doesn't work.
Leanne_T
Hi @CAHodson
Thanks for coming here.
Are you using a pay as you go or pay monthly plan?
If pay monthly, have you activated roaming in My EE? Go to Menu > Account Settings > Control Content > Roaming abroad and Call abroad, do they show as ticked?
Schockwave
Hello @CAHodson ,
Welcome to the community,
If you are on pay as you go, roaming is all set up and you just need to make sure that you have enough credit.
If on contract, did you make sure that roaming, call abroad and premium calls are enabled? If not are you able to do so in settings either logging in via the My EE App or online?
Have you tried doing a manual search for a network if automatic network is not working?
You can ring customer service using Skype for free:
https://ee.co.uk/contact-ee/account-billing/mobile
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
