Roaming
imy_sv
If i have forgotten to send a ROAMING TEXT before going on holiday to 150
can i fix this
@imy_sv   Login to your my EE app and enable it.  If you can not enable it you’ll have to call customer services from a different device to have it enabled.
On the app go to mobile plan (it’s at the top ) then scroll to settings ( it’s at the bottom to you’ll need to scroll down ) click check settings then enable “ENABLE ROAMING”
@imy_sv : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Having a roaming add-on doesn't of itself activate roaming on your a/c.
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
