Roaming
Aitch8013
Good morning all.
I have a Roam Further add on that was added before I went on holiday to the USA.
since I landed I have not been able to use any of my data or receive Text or calls until I long onto the hotel WIFI.
I have checked all my settings and they seem to be correct.
I keep receiving text stating I need to buy a roaming data add on why is that when I already have the add on.
any help would be great.
Christopher_G
Hi @Aitch8013
Welcome to the community.
Is the Roam Further add-on showing as active in your My EE account?
@Aitch8013 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
