Roaming/receiving calls in Pakistan
salmantakkhar
Hello everyone, urgent assistance please. Am in Pakistan for a few days and am not able to receive any calls. Can someone please assist guide what I need to do ? The cost of receiving calls is not a problem.
please help !
@salmantakkhar   Do you have a signal showing on the device?  If you’ve a contract customer have you enable roaming from within your online account?
6 REPLIES 6
@salmantakkhar : Can you make calls & texts?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
Yes it does show a signal.
Sent from my iPhone
Thanks a lot Chris , sorted
Thank you very much Xrayspex , followed your steps and its sorted. You are a star
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
