Roaming not working
lumahh
I’m in Spain and I activated roaming   before coming here, however it doesn’t seem to work - I can’t send sms or make any phone calls. Anything else I need to do?
Does your phone show signal bars of a local network?
If you login to your myEE online account, goto "Parental & data controls", do the following 2 options show as enabled? They need to be, and if you're not able to activate them for whatever reason, you will need to call EE C/S
1: International roaming
2: Call abroad & Premium rate
I suspect that when you say "roaming was added", that the billing add-on was done but the roaming facility itself (which allows your phone to connect to a foreign network) hasn't been.
You've posted in the PAYG section of this forum, so I presume you have a PAYG phone.
PAYG lines are auto-enabled for roaming, providing you have used your phone in the UK before leaving for a foreign country.
The requirement to activate roaming on your account only applies to pay-monthly phones.
Are you on PAYG or pay-monthly, and if on PAYG - have you used your phone on EE's UK network before travelling abroad?
Apologies, I posted in wrong section as I have a new sim-only contract with Smart benefits and roaming was added when I was in the store so there should not be any reason why it should not work
thanks for the info !
Thanks! I followed your tips and it finally worked 👌🏻
Leanne_T
Thanks for coming back and letting us know @lumahh
Have a lovely time 🙂
