Roaming not working in the Philippines
Micp15
I am currently abroad and bought  roaming but wasnt able to use it. Every time i turn it on it says sign in to network. I tried reseting with flight mode but to no success.
Also, i bought the roaming with 100GB for7 days twice thinking the first time didnt come through because it is still not working. Internet reception here is really bad. Can anybody help me with this and get a refund  for my 2nd roaming purchase.
19 REPLIES 19
James_B
EE Community Manager
Hi @Micp15,
If they have activated roaming, it can take up to 24 hours to reflect on your account. You'll receive a text when it is up and running.
Thank you so much for addressing my roaming issues.Sent from my Galaxy
James_B
No problem @Micp15 🙂
Elephantinthe
Try this:
Otherwise login to your MyEE account online & go to Menu > Account Settings > Parental and Data Controls > Roaming Abroad and also Call Abroad and Premium Rate. They will show as ticked if roaming and calling abroad is activated. If not ticked, can you activate these settings?
I had same problem I had left UK and already in USA. I could get nothing except specifically on hotel Wi-Fi. xRayspecs told to log into My Ee and then I did these steps just above ^^^ It worked when nothing else would. Basically my data roaming was not turned on within My EE even though I’d paid for roaming pass and everything. The problem is within your My EE permissions not your phone or anything.
I wish you luck / I’m just a tourist
I tried ticking the enable roaming but it says error and i need to text INFO to 150. However  i cannot send the text too since my roaming is not activatedSent from my Galaxy
So call CS using Skype over WiFi as I suggested.
Should i call again? I called them yesterday and still awaiting for their text which i dont know if i could receive one because i dont have roaming.Sent from my Galaxy
Christopher_G
Hi @Micp15
Try restarting your phone first. If it still isn't working, it may be worth another call.
Thank you to the costumer help line for sorting out my roaming issue. Shout out to connor from techincal team! Sent from my Galaxy
Christopher_G
I'm glad Connor was able to get you connected, @Micp15. 🙂
Thanks for letting us know.
