Roaming not working in USA
Nat767
Hi
i am in the USA and my roaming is not working.
i cannot dual 150 or call the technical line from my phone.
i have tried using my hotel phone and it just gives the message that the number I am trying to dial is not available
can anyone help please?
drzia
Skilled Contributor
Skilled Contributor
Download Skype using wifi and call EE helpline from Skype for free.
Hopefully, they will be able to figure it out for you.
Skype: +44 800 079 8586 or +44 800 956 6000.
I hope your problem will be sorted out.
Thank you.
@Nat767 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Schockwave
Hello @Nat767 ,
Welcome to the community,
Are you on pay as you go or monthly contract?
If on contract did you enable roaming on your account? You do not need to do this with pay as you go as this is autoenabled.
Did you receive the welcoming message when arriving in the USA?
Have you tried searching manually for a network?
