14-06-2022 11:27 PM
Urgent help needed.
I am in Italy travelling. My plan in the uk gives me 163gb and I have used this in France usually with no extra charge and never capped. Now in Italy I am unable to use any data at all, I can’t text 150. I want to be able to use my data at usual, I have roaming on as usual, someone please help.
14-06-2022 11:31 PM
@Judedoesntknow : You are limited when roaming on contract to 50GB data / billing month. It's a FUP of your T&C's.
15-06-2022 07:43 AM
Hi @Judedoesntknow,
Which plan are you using? When did you take it out?
Are you able to make calls?
15-06-2022 09:16 AM
15-06-2022 09:27 AM
15-06-2022 11:43 AM
How do I gain more roaming data? I’m not good at tech stuff so please keep it simple.
15-06-2022 11:49 AM
Hi @Judedoesntknow,
To check your eligibility for EU roaming, please can you let me know if you took out your plan before or after 7 July 2021?
15-06-2022 02:29 PM
15-06-2022 02:31 PM
