Roaming in venezuela not working
polaco_loco
Hi
Even though I called before arrival in venezuela the roaming doesn't work
I can't connect to aby network automatically nor manually
WiFi works but it gave me a lot of trouble at the airport here when trying to book a shuttle from the hotel as I can't really use taxis here as its not safe
Please fix as I cannot connect to any MNO
Northerner
Hi @polaco_loco
Have you checked the roaming settings in your EE app and on your device?
Log into your on line account and then Menu - Manage Device - make sure you have activated roaming and international calls.
Or
From the MyEE app Click on the person icon in the corner - Settings and Permissions - activate roaming abroad
@polaco_loco : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
