03-09-2022 12:58 AM
Just landed at JFK and my phone isn't connecting. I'm on a pay monthly, roaming is enabled, I've got the roam abroad add on. I've tried manual connection and restarting the phone but not working. Really need service to connect since I'm here a while. I was in France a few weeks ago and it worked fine. I'm using a pixel 4a
03-09-2022 01:41 AM
As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
30-10-2022 02:01 PM
What was the solution?
30-10-2022 02:26 PM
Hi @AnnoyedbyBS
Have you tried restarting your device and manually searching for an available network?
Are you on contract or pay as you go?
15-12-2022 04:51 PM
Can’t call if no roaming it’s hopeless 150 errors!!
15-12-2022 04:58 PM - edited 15-12-2022 05:00 PM
@Jax47 : You don't need mobile roaming when you call over Skype as I suggested.
