on 17-01-2024 06:12 AM
Arrived into Amsterdam, applied for daily roaming package. Connected to Odido “automatic network” selection. Zero data!, cannot make a call, send a txt, use my apps.
tried to connect to other networks but zero success! Any ideas
Solved! Go to Solution.
on 17-01-2024 08:28 AM
If you now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
