on 24-12-2022 02:54 PM
Run out of ideas… being billed to roam but can’t make calls or receive data in Spain
Went to an EE shop, they said nothing wrong with phone but abroad and can’t call again…
any ideas?
on 24-12-2022 03:24 PM
@Goose440 Have you enable roaming on your account? You purchased an add on so you can use your allowances this doesn’t enable roaming on your account these are different things.
on 24-12-2022 06:24 PM
Can your phone connect to local networks in your country? If not, then there's a strong likelihood roaming isn't enabled on your phone.
Roaming isn't a phone setting that can be checked in a shop, it's an account-level network setting.
on 24-12-2022 06:42 PM
Thanks for your responses, I have paid for roaming, enabled it by texting Roaming to 150 and phone has connected to a local network provider but can’t call or use data, any ideas?
on 24-12-2022 06:54 PM
You don't pay for roaming, you pay for a billing add-on. Roaming itself is a free facility,
However, if you're connected to a local network then roaming is enabled. What happens when you try calling or using data? Can you receive calls and send/receive text messages?
Manually selecting an alternative local network is standard advice in these scenarios and often resolves issues.
