10-09-2022 03:05 PM
we are currently abroad my husband purchased a roaming plan but he can not access to the internet.
10-09-2022 03:16 PM
@Jac02 : Can you make calls & texts?
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
