07-03-2022 10:45 AM
I spoke to two EE reps on Wednesday to enable a roaming plan; however, both calls dropped before completion. I am currently in quarantine and my phone have no service. I do not have access to another phone to contact EE. I tried to turn on roaming in my account settings but it wouldn’t let me. Is there any other way I can contact EE to get this fixed?
07-03-2022 10:53 AM
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
Often just rebooting the phone is the simple remedy. Otherwise try logging into your MyEE account online & go to Menu > Account Settings > Parental and Data Controls > Roaming Abroad and also Call Abroad and Premium Rate. They will show as ticked if roaming and calling abroad is activated. If they are not ticked, can you activate these settings?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. over Skype. It should be free.
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
07-03-2022 10:53 AM
07-03-2022 11:08 AM
Hi, thank you … I called them through Skype and I am currently on hold.
07-03-2022 01:26 PM
Thanks! You're welcome 🙂 ! Glad I could be of assistance & hope it soon gets sorted.
