31-05-2021 01:34 AM
Hi can somebody advise me going to Ukraine for 3 weeks and want to buy add roam further, in google found that Ukraine is in EE zone A, if I purchase this add can I use my min and data in Ukraine the same as in UK???
31-05-2021 02:40 AM
The Roam Further Pass is no good to you in Ukraine. It's only for USA, Canada, Mexico, NZ and Oz.
You don't need to buy a roaming add-on there. You can just use your UK allowances anywhere in the EU.
31-05-2021 02:40 AM
31-05-2021 08:44 AM - edited 31-05-2021 11:46 AM
Hi @mb_e320 ,
I'm sure you are already aware that Ukraine is not a member of the EU and my monthly price plan says it is in Zone 6 for roaming (corrected from Zone 5 when calling from UK, I believe) which is considerably more expensive than EU countries.
Edit3: in an earlier version I said Ukraine was in Zone 5 but this would only be relevant for calling from the UK to Ukraine. As the OP is travelling to Ukraine, I changed the text to say Ukraine is in Zone 6 for roaming purposes. Apologies for not more clearly marking out the above edit. (Errors and omissions excepted.) 🤓
I would recommend that you look up the relevant price plan for your SIM and double check the situation.
Edit: possibly useful supplementary info: https://ee.co.uk/help/help-new/roaming-costs/countries/ukraine
Edit2: here is some good guidance: https://www.4g.co.uk/news/best-network-for-roaming/
31-05-2021 11:24 AM
Correct. Ukraine is not in UK. I looked it up wrong 😞 !
Not "corrected"! Diff Zoning.
