Reception in Cayman islands
Ws4037
My phone is not working at all apart from on Wi-Fi. Please can you help?
@Ws4037 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
