Re: WiFi Calling - Please fix it EE
GrahamJP
I Know this is an old thread, but i wanted to share my experience of this issue.
I too suffered from dropped calls when using wifi calling, i do have between 1-2 bars of 4G inside the house but the signal drops intermittently and my outgoing audio drops out.
When using wifi calling, approximately 30% of my calls would get disconnected, i tried using different wifi access points to rule out the router and all had the same problem.
When i did eventually get through to EE tech support they could see the dropped calls and told me the reason was the phone constantly switching from wifi to 4G and back as the 4G signal changed in signal strength.
They advised me to use 'Airplane mode' and re-enable wifi to kill the 4G radio so it would not switch over, this is fine except you have to remember to switch off Airplane mode when you leave the house and on again when you come home, Not ideal!!.
Apparently, on older versions of Android (Android 11) there was an option to select 'prefer mobile network' or 'prefer Wi-Fi', which has been removed in later software updates.
However, this option is still available inside the operating system but no access to it from the UI, it can only be accessed by using the Android Debug Bridge (adb) software package installed on a PC (Win, Mac & Linux) and connecting the the phone by USB or WiFi.
This gives you access to the internal settings of android, the one which needs to be set is 'global wfc_ims_mode', this can be done by issuing the following in a terminal on the PC:  "adb shell settings get global wfc_ims_mode" - to read (Default is null)  and: "adb shell settings put global wfc_ims_mode 2" - to set,
This can be set to:
0: Wi-Fi only
1: prefer mobile network
2: prefer Wi-Fi
I initially set this to '2' but still had some dropped calls so i have now set this to '0'
This allows the phone to switch from WiFi to 4G only when the wifi signal is lost (when you go outside) and should switch back to WiFi when your phone gets back in wifi range, without the need to keep changing any settings (Airplane Mode)
You do have to be in 'Developer Mode' on the phone to perform the above changes, this was my solution to the problem and while i appreciate that not many people would even attempt to do this, it is not ideal from a user perspective and should not have to be done by people just to get access to a network feature.
The real solution would be to have the options in the UI to set the preferences you desire, this i believe is not the fault of the carriers, but  down to the phone manufacturer and/or the android developers (Google)
This may or may not help but until we get the option back in the UI it is just one solution
Graham.
Telecomms Engineer (Retired)
That option is available on some Android versions - here's mine.
WiFi-calling options within "call settings" menuWiFi-calling options within "call settings" menu
PhilipL
Thanks for the information.  The UI option generally is set or hidden by the carrier and it is whatever they decide, i.e. show it for the customer to have the choice, or hide it so it can't be changed from the carriers preferred setting.  The other confusing issue is some devices will ignore the carrier request to hide the UI will show the Wi-Fi calling settings anyway, or they don't receive any specific settings from the carrier so my show or may not show these extra settings, as the option is then up to the phone manufacturer what they default to.  For example on Xiaomi devices you can dial a special code and make it show the Wi-Fi calling UI (and option to turn on or off VoLTE) regardless if the carrier wants it hidden.
If all else fails then setting via adb is the way to go, but I think this one is on EE, they've have made the settings hidden on your device, and this has been a common complaint with EE for some time.
My settings menu on EE on a Xiaomi device, note that option 0 for Wi-Fi only I don't think is ever seen as an option, I've only seen the UI showing Wi-Fi Preferred or Mobile Preferred.
cds1450
Thanks for this. Explains exactly what my problem is. I get fed up with being told to use WiFi calling for my poor signal but the problems using that are worse than the weak signal.
I noticed no ee response !!
