on 01-04-2024 06:13 PM
Short answer.....It sounds unconvincing but I am now convinced after a month in the US that the roaming pass doesn't work for WiFI calls
on 01-04-2024 06:24 PM
The post you'd added to was over 2 years old so it's been moved to a new thread.
WiFi-calling is not supported abroad but can sometimes work, it should be charged as a standard roaming call if/when it does.
Do you have an issue using your EE phone in the US? If so, what is the problem?
