Re: Why am I being charged for making calls to the UK on WiFi from the USA?
Kieran180401
Hi I made a call to USA by mistake without thinking it will cost and I changed my number yesterday cause they kept calling will I still be charged it was a 25 min phone call
8 REPLIES 8
@Kieran180401 : Yes, you made an International Call on your (old) no.
EssexBoyEE
You only get charged extra for Out Going Calls to the USA, any incoming Calls to your Mobile are not charged to you, the Caller pays the cost, this the same for both Cell phone Calls over the Mobile Network or using Mobile WiFi.
What if I called them and they didn’t answer and it went to voice mail does it still charge
If it goes to VM you are still charged. A connection has been made.
What if it rings and I hang up does it still charge sorry about this I’m just worried
No, no connection is made.
Alright thank you I’m just worried
If you gonna make regular International Calls from UK, consider ...
International calls & texts to overseas nos. from UK can be rather expensive but EE has a add-on, free on PAYG or £2 pm on contract, that anyone, on PAYG or contract, can apply for to give these calls & texts at a fraction of the standard rates. See The CALL ABROAD Add-on for Cheap Calls/Texts from UK .
