Re: Voicemail pin number
Mjperez
Help me set a new pin
Katie_J
Hi @Mjperez.
You can change your PIN by doing the following:
  1. call your voicemail (press and hold 1)
  2. skip to the main menu by pressing *
  3. select option 3 – settings and features menu.
  4. select option 3 – change your PIN.
  5. enter a new PIN, then press # to save.
Katie
8 REPLIES 8
Katie_J
Hi @Mjperez.
Katie
Don't you need your original pin number for that to work? What if you've forgotten it?
If you have VM-PIN protection on and have forgotten your PIN, CS can reset it.
This doesn't work on my Android. When I press and hold 1 the voicemail message comes immediately, not giving me a chance to press * (the keyboard disappears as well).
Katie_J
Hello @ElisaGusmao.
When you have called your voicemail by press and holding 1 please then follow these steps from your voicemail menu.
  1. select option 3 – settings and features menu.
  2. select option 3 – change your PIN.
  3. enter a new PIN, then press # to save.
Let me know how you get on,
Katie
Same as before happens again.
James_B
EE Community Manager
What message do you hear when you connect to voicemail @ElisaGusmao?
This is what  happened  to  too
