Re: Unable to connect to network abroad despite Roam Abroad Pass
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
27-07-2024 02:57 AM - edited 27-07-2024 02:58 AM
Same problem, pay monthly phones, activated Roam Abroad prior to leaving the UK and received confirmation texts. Arrived in Canada - no 4g, no mobile network. Unable to contact/make calls on WiFi calling in order to resolve this. What's the issue please? Already tried restarting the phones, on and off airplane mode, manually selecting local networks, nothing.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
27-07-2024 09:23 AM
Hi there @Mattcork
Welcome to the community.
I am sorry to hear you have no service in Canada.
Did you text ROAMING to 150 at the same time as the Roam Abroad Pass to activate roaming on your account?
Speak soon.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
27-07-2024 09:39 AM
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
27-07-2024 01:11 PM
I activated Roam Abroad via the EE app for two numbers on my contract (mine and my wife's phone), this is confirmed by checking the add-ons, they are both active. No network registered, no 4g. Unable too manually select a network. Not able to call any customer service via WiFi calling...
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
27-07-2024 01:13 PM - edited 27-07-2024 01:13 PM
Yep, activated it before leaving. Unable to call any CS via any method. Any more suggestions?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
27-07-2024 01:20 PM
Read my post above. You're referring to billing add-ons, which reduce the cost of roaming.
They do not, of themselves, activate the free roaming facility which enables access to foreign networks. If you are certain this has been done, then manually cycling through each available local network should eventually obtain coverage.
Otherwise, refer to paragraph 3 of my previous post.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
27-07-2024 08:04 PM
Please stop repeatedly posting this as a solution. It does not address the issues that individual users are having.
If you have a specific answer to the above technical issue ("It gets me on for 10 secondes and I get kicked out no matter which network I select. I get “sos” display on the status bar almost immediately."), brilliant. Otherwise, the advice you are giving is generic and unhelpful.
Was there ever a solution to this as CS didn't know...
Thank you.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
27-07-2024 08:21 PM
By the same token, it's much better to keep all your queries on one subject to your own thread and not cross-post to others - your latest post has been moved to your existing thread. I make no apology for posting what is valid advice.
As a regular contributor to this forum, very many of the queries can be answered by an "FAQ" or generic advice as you term it - and variations on "I've gone abroad without roaming" is one such scenario.
If you have specific issues after CS have assured you that roaming is enabled on your SIM, you should pursue those through CS with a view to a single-user fault being raised if necessary.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-07-2024 02:35 AM
You never texted ROAMING to 150 before leaving UK! Texting ROAMING PASS to 150 to get the Roam Abroad Pass is not the same thing as has been explained to you.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
28-07-2024 05:23 AM
Nope, still not quite there, but thank you so much for the time and effort.
As stated in my original query, I activated this prior to leaving and it was confirmed on the app and by text. My purpose of 'cross posting' was to find out if that poster had found a successful solution, so I'll return to that post and repeat my request.
- Mobile Network upgraded in Mobile Network discussions
- Making and receiving calls while abroad in Roaming
- I'm trying to buy a Sim only deal but the form has errors that can't be fixed in SIM cards & Porting
- Instantly disconnecting from foreign landline number in Mobile Services
- Scam calls and Scam Guard - a lesson in marketing over a solution to a problem. in Mobile Network discussions
