Re: Unable to connect to network abroad despite Roam Abroad Pass
clark58
In the same boat as Mike was 2 years ago. Have had a Roam Further add-on for several years and am now in Canada  - with no network connection!  : (
Katie_J
Hi @clark58
I am sorry to hear this.
Did you activate roaming before leaving the UK by texting ROAMING to 150?
Has this previously worked OK?
Katie
@clark58 : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
