13-08-2021 12:23 AM
Im having the exact same issue how do I sort this ( one specific phone also a Nokia)
13-08-2021 07:31 AM
Hi @Nat944.
Welcome to the community.
Are you able to receive calls and texts from this number?
Are all other numbers fine?
Jon
13-08-2021 01:50 PM
13-08-2021 02:27 PM
13-08-2021 02:29 PM
13-08-2021 02:56 PM
Thanks @Nat944.
Did you factory reset your old iPhone?
Are you able to try your SIM card in another phone? This would help us to rule out your phone as being the problem.
Jon
13-08-2021 03:01 PM
13-08-2021 03:31 PM
13-08-2021 03:37 PM
13-08-2021 03:45 PM - edited 13-08-2021 03:46 PM
Thanks @Nat944.
If you've already tried your SIM in another phone and the issue still persists it's unlikely to be your phone that is causing the issue.
Can you check your blocked list under Phone, then Blocked List?
Jon
