Re: SMS text going to other phone without SIM card?
Imagestreet
I have this exact same issue.  A 'test' SMS went through to the old phone even with no SIM.  The message doesn't have a box around it.
Leanne_T
Hi @Imagestreet
Thanks for coming back to us.
Can you make and receive calls?
Does the SIM card work for texts and data in any other phone?
7 REPLIES 7
Hmm, I tried using textra (and the test messages I sent popped up).  I then went back to Google Messages and set that back to the default messaging app, but it still didn't work.  Weird.
Leanne_T
Hi @Imagestreet
Thanks for coming here.
Which model phone has received the text?
Have you recently received a new SIM card or transferred your number from another network?
It's a brand new Redmi 2022 which I've inserted the old SIM card.  I now have no mobile internet connection, and am not receiving texts or able to browse the web.   I assumed this would automatically adjust after a while but it hasn't.
I've changed my APN settings to the EE recommended setup option  - still nothing
Leanne_T
Hi @Imagestreet
Turns out the phone had a fault - replaced it with the same model, and it now works perfectly.
James_B
EE Community Manager
Glad you got it sorted @Imagestreet
Thanks for the update.
