Re: Roaming
Samtodd123
I am Roaming in Spain but didn't text Roaming to 150 before I arrived....what can i do now
On pay-monthly, this needs to be enabled manually - usually by texting ROAMING to 150 before leaving the UK.
If you now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
