Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Re: Roaming problem
libiojose
I can make any call o sent text in italy, this do not suppose to happen because I have the roaming plan
Northerner
Hi @libiojose
Use Skype over wifi and the number in my signature to call EE.
@libiojose : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
