Re: Problem with EE mobile in Canada
Spyker
Same problem for me the above 0800 number doesn’t work either and EE chat bot is useless been trying 4 days now to get them to cal me on what’s app but no good. Got conned into paying £25 per phone to ensure it works too🤦🏻‍♂️
