Re: Please enable roaming remotely
Helenjayne
My roaming is not working in the US either regardless of me setting it up before I travelled. It’s very disappointing 😔
Katie_J
Good morning @Helenjayne
Thanks for coming here.
Are you connected to a local network?
Did you receive a welcome text when you arrived in America?
Katie
@Helenjayne : What roaming did you set up? How? Where?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
