on 09-07-2024 07:47 PM
I am having the same problem. The mobile is on and not busy. There are no redirects and no VOLTE. The call goes straight to voicemail and a message is left but I get no indication that a message has been left.
Using Android and oneUI.
How do I sort this?
on 09-07-2024 08:35 PM
Can you make outgoing calls? Is this a recent problem? Lack of voicemail notifications is a separate issue, of your VM config.
Can you receive other text messages OK?
Are these missed calls happening in a specific location, or more generalised?
