Re: Outgoing calls
denterprised
I'm having the same problem did you get a fix?
nrsteady1
Hi, I think doing a restart did the job. Possibly it was a firmware update that required restart.
I have already restarted it -it did not fix the problem
Katie_J
Good afternoon @denterprised.
Is this happening in one location?
If yes, please check for any known issues using our Network Status Checker.
Speak soon,
Katie
