Re: Mobile not working in ireland
Rachel3101
Mine isn’t working either. This seems to be a running theme
Leanne_T
Morning @Rachel3101
Do you have a pay as you go or pay monthly account?
If the account is pay monthly, did you text ROAMING to 150 before travelling?
Regardless of any billing add-on, your ability to get coverage abroad (which calls, texts & mobile data rely on) is dependent on roaming being activated - which allows your phone to connect to foreign networks. It is, sadly, quite a common theme for people to travel abroad without enabling roaming.
