Re: International roaming
Abioduu
Hi good afternoon I m in Nigeria  I need international roaming im expect otp from bank how can  you help and I want to pay my telephone bill with ee
James_B
EE Community Manager
Hi @Abioduu,
Have you activated roaming in the My EE app? Go to Menu > Settings > Roaming to check.
For help with paying your bills, please see How do I pay my phone bill?
@Abioduu : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming as long as you've used the SIM in the UK previously. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
