Re: International Roaming 'blocked'
Hegarty1
Hi I'm in Spain and cannot send text messages to uk
Leanne_T
Hi @Hegarty1
Thanks for coming here.
Are you with us on pay as you go or pay monthly?
Can you make calls?
Leanne 🙂
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
