Re: How do I activate international roaming so I can use my phone in Europe?
lizzyo60
I can’t txt roam as I only have sos and no signal as it’s a new phone bought in USA on holiday
9 REPLIES 9
Katie_J
Good morning @lizzyo60.
Are you trying to activate roaming in the United States using a new phone?
If yes, did your EE SIM work OK previously?
Katie
lizzyo60
Yes when I arrived it worked but new phone has an esim so I’m guessing that’s why. It seems to be just txts as 4g is letting me use the internet and apps
Sent from my iPhone
Katie_J
Thanks for getting back to me @lizzyo60.
Have you activated an eSIM on your new phone whilst abroad?
If yes, we recommend doing this in the UK on the EE home network.
Katie
lizzyo60
Hi, yes. It was all done in the Apple shop as I put my old phone in for part exchange. So I’m guessing when I get home I should do it then? It’s just I need to relog into some apps and can’t do this without a verification txt
Sent from my iPhone
Leanne_T
Hi @lizzyo60
Can you receive texts from other numbers? is this just verification texts for the apps?
Leanne 🙂
lizzyo60
Just texted myself from husbands phone and it’s fine and I can txt him from mine so it just seems to be the apps
Sent from my iPhone
Leanne_T
Thanks @lizzyo60
Could you try when you get home and let us know if you have any problems with the verification texts?
Leanne 🙂
lizzyo60
Hi. Yes I will. I’ve just spoke to ee and they can’t activate while I’m out of the country so I need to do it when I’m back next week. A bit of a pain but most other things are ok
Sent from my iPhone
Leanne_T
I see @lizzyo60
Thanks for coming back and letting me know.
