Re: Contacting EE from abroad with a phone that won't work
Idris1996
I’m in USA I want use data how can use it
9 REPLIES 9
Leanne_T
Hi @Idris1996
Can you make calls and send texts?
Do you have a pay as you go or pay monthly account?
Thanks 🙂
No
i use monthly with EE
Leanne_T
Thanks @Idris1996
Did you text ROAMING to 150 before going abroad to make sure the account was set up for roaming?
Do you have signal showing?
No I didn’t set up can you do it for me please
@Idris1996 : Did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming billing add-on doesn't of itself activate roaming on your a/c. Having roaming activated on your EE a/c, not just on your device, is crucial to using your contract SIM abroad.
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
Leanne_T
Hi @Idris1996
Sorry we have no account access on the community to set up roaming for you. You would need to contact us from any other phone or VoIP service such as Skype.
Please see our Contact EE page for numbers you can call from abroad 🙂
No I didn’t
but can you do it for me know please
No! This user discussion forum can have no access to your specific account. You need to raise this with CS. I gave you a way of doing so that doesn't need your phone & should be free.
If you are on pay-monthly and now find yourself abroad without having enabled roaming, your only recourse will be to contact CS to request it activated. You can either contact +44 7953 966150 from another working phone, or +44 800 0798586 using a web-calling app such as Skype over WiFi.
