Re: Calls keep failing
Mohammedislam
My calls are kept fail
Mohammedislam
Why my every calls go fail
Debbie_G
Hi @Mohammedislam.
I'm sorry to hear you're experiencing issues with your calls failing.
Are you able to receive calls and send or receive text messages? Does this happen in all locations?
You can check for any issues in your area using our Coverage Checker, where you can also report any problems you're experiencing.
Debbie
