06-12-2021 07:57 PM
pay monthly
06-12-2021 11:16 PM
You can enable call waiting by using your phone's call settings menu, it's not an option on the voicemail menus.
The exact location of this menu will differ between Android & iOS devices.
06-12-2021 08:04 PM
@Guna4u Have you enable it ? It’s off by default. Hold down the number 1 key on your dial keypad until it calls you voicemail then listen to the options given and select the correct option.
06-12-2021 11:16 PM
07-12-2021 07:32 AM
@bristolian I was thinks of something else. Thanks. 👍
