15-02-2023 12:30 PM
I'm outside UK, I'm paying EU roaming but I CAN'T CALL or TEXT with my data. is there any solution?
Thank you
15-02-2023 12:36 PM
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
