05-09-2023 07:46 PM
Hi there.
Samsung S22
On the "configure mobile hotspot menu", the option to switch off "protected managemet frames" is greyed out. Is there a wsy to this off?
THANKS.
05-09-2023 07:51 PM
Why, what's it gonna do for you?
05-09-2023 07:59 PM
Just trying different options to try and get the phone to hotspot a nintendo swich gor multiplayer gaming.
Thx
05-09-2023 08:10 PM
It's just a WiFi safety feature. It's not gonna clear your Nat Type issue.
05-09-2023 08:18 PM
Seems like I have tried everything else so I thought i would give it a go. Buy if you are certain that its not a possible solution i will leave it alone.
It seems that only solution to the nintendo NAT type problem is to pay extra for a VPN service.
