on 07-09-2022 04:02 PM
Hello. I have an EE sim card that I cannot use. I bought 50 GB today and I only see 4G but I cannot load any website. What may be the problem? I am not in England but in Germany. ROAMING at 150 does not work. Has anyone had a similar problem?
on 07-09-2022 04:18 PM
Hi @soldat007
Welcome to the community.
Could you check to make sure that roaming and international calling are both enabled in your My EE account? It's under account settings > parental and data controls.
on 07-09-2022 04:28 PM
Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
If you can't enable the Roaming Abroad and the Call Abroad & Premium Rate settings of your online MyEE, you will need to call CS. Try calling CS on the Freephone no. in my sig. via Skype over WiFi. It should be free.
PAYG is auto enabled for roaming as long as you've used it in the UK previously. You won't see any of those settings & don't need to change anything.
07-09-2022 04:38 PM - edited 07-09-2022 04:39 PM
Only to moms. I can't see parental controls.
on 07-09-2022 04:45 PM
What's the bottom part of that page that you are not showing us?
on 07-09-2022 04:46 PM
Knock code and below "Account details"
07-09-2022 04:57 PM - edited 07-09-2022 05:03 PM
Knock what? You've only posted half a page. It doesn't work that way that you can click some part of an image & see what isn't included. It should look more like:
on 07-09-2022 05:04 PM
"PUK" code. Well, it looks like this, but where is this "parental control"?
on 07-09-2022 05:10 PM
Like what? There's nowt there! We're going round in circles with no advancement.
on 07-09-2022 05:11 PM
What to do?
