Pnone won't allow texts to be sent or receive and emergency call only any ideas
Alan13631
Last 3 days unable text or receive and emgency calls only Any ideas what wrong
Katie_B
Thanks for getting back to us @Alan13631
I would recommend giving us a call so our mobile care team can look into your account further.
The team may need to do a Network Refresh or send this to another department.
Please be sure to keep us updated.
Katie
7 REPLIES 7
Katie_B
Hello @Alan13631.
Welcome to the community.
Are you in the UK at the moment?
Is your SIM pay as you go or pay monthly?
Speak soon,
Katie
Hi katie
Yes in UK and pay as you go
Thks alan
Katie_B
Thanks for confirming @Alan13631
When was the last time you used your SIM?
Does this happen in multiple locations?
Katie
Used OK on Tuesday then this started all time with plusnet no probs since
gone ee probs
Alan
When did you last use it for a chargeable action? EE PAYG SIMs are deactivated after 6 months of non-chargeable use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
Made calls and chargeable actions all time only seems to be last week gone
like this after transfer from plusnet
Katie_B
Katie
