on 09-01-2024 02:05 PM
on 09-01-2024 02:07 PM
Can you explain how your phone is "not working"? Does it show a connection to any Spanish networks?
Are you on PAYG or pay-monthly?
on 09-01-2024 07:03 PM
@Villaricos : Can you make calls & texts?
Often just rebooting the phone is the simple remedy. Also try selecting a network manually rather than auto. Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
