Phone not working in USA
Annmcguff
I added ROAMING to my account a few days before leaving UK and received texts saying it’s ready to use. It’s been added to my bill. However, I am unable to make any calls, either to US or UK numbers. Have tried switching on and off; have done everything I’ve seen on the forum here, including trying to contact customer services, which doesn’t work!
Please help! I need to contact the home my elderly mother is in….
Thank you in anticipation ,
Ann
Annmcguff
For others having the same problem this might be a solution…….
Have solved it after a lengthy on line chat with EE…..
My phone was set to automatically choose the network on roaming…..it went to AT&T. After sliding the automatic choice off and changing to T Mobile I now have full signal and can make calls to both US and UK
@Annmcguff : As you are on contract, did you activate roaming on your EE a/c before you left UK by texting ROAMING to 150? Having a roaming add-on doesn't of itself activate roaming on your a/c.
Annmcguff
Christopher_G
Thanks for letting us know what the solution was, @Annmcguff.
Enjoy the rest of your trip. 🙂
jez6363
So I had the same problem with two phones - data was working, but not calls (though texts also worked). I don't believe its actually AT&T that is the problem, but that sometimes when your phone first registers on a network it fails somehow, leaving it messed up. What you need to do is register with any other network, then turn back on automatic registration, and let it do its thing.
Phone 1 - was registered with AT&T via automatic registering. Changed it to Verizon and it worked. Changed it back to AT&T and it still worked.
Phone 2 - an additional wrinkle - for some reason - VoLTE calls - Use 4g whenever possible for calls - was turned off. I had to enable this, and also do the force a change of network thing.
One more thing - when I arrived in the USA the phones got a message about some ridiculous addon that would cost over £7 a day and have only 1gb data. Before leaving I had asked them to set up the "Roam Anywhere", which costs £10 a month and extends your whole plan to the USA and Canada. So I was surprised to get the wrong text messages. Upshot was I was on the £10 option, and I checked by testing ROAMING to 150, which confirmed it.
If you are traveling to the USA, or indeed most countries, you should ask about Roam Anywhere, if its available on your plan!
Leanne_T
Thanks for sharing @jez6363
I am sure this will be helpful for other customers 🙂
Details on the Roam Abroad Pass can be found in our How do I get the Roam Abroad Pass? Help page.
