Phone not working in Barcelona as my daughter says it will not connect?
vanessalee
Mobile phone not working in Barcelona Spain what could be the problem ?
@vanessalee : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
