on 26-05-2024 10:52 PM
My roaming/wifi isn’t working abroad and not sure why. I have accessed the app to connect but I’m already connected in my settings/ network. Any advice would be appreciated, thank you.
on 26-05-2024 11:03 PM
@lfinnegan3012 : Are you on contract or PAYG? Had you used that SIM for making calls or texts in UK before you left to go abroad?
Otherwise you need to call CS to get your roaming activated. Try calling CS on the Freephone no. in my sig. on Skype over WiFi. It should be free.
on 26-05-2024 11:33 PM
WiFi is just a connection between a mobile device & broadband router, it has nothing to do with any mobile network.
Does your phone show a connection to any mobile network in your host country? Did you receive a welcome text message on first arrival?
