Phone calls
Lorraine68
I am trying to call home
I have roaming on my package but calls aren’t allowing me to phone out
Are you in the UK or abroad?
Do you have signal bars showing on your phone?
Are you on PAYG or pay-monthly?
@Lorraine68 : Are you on contract or PAYG? Did you use that SIM for making calls or texts in UK before you left to go abroad?
PAYG is auto enabled for roaming. You won't see any of those settings & don't need to change anything. If outside EU, do you have enough credit for making calls & texts from abroad?
