Phone calls abroad calling a different number
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-09-2024 10:59 AM
I spend a bit of time in America with work, and whenever I try and call a UK number, it redirects me to the Qantas Airlines booking phone line or other random businesses... Of course I checked the number and made sure that I used the correct dialing code for being abroad, same result. Anyone had similar?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-09-2024 06:12 PM
Hi @Isaac10,
Thanks for visiting the EE Community
Are you in the USA at the moment? I take it you can call US numbers ok when there, its only when trying to call outside to the UK you get the issue?
What type of phone is it you are using and what is the dialling code you are using to confirm?
Alex
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-09-2024 06:14 PM
I'm in the US, trying to call a UK number. iPhone 16 Pro (also happened
with my 15 pro a few weeks back) using +44.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-09-2024 06:46 PM
@Isaac10 If you go into Settings> Phone> Dial Assist do you have this turned on?
Have you tried connecting to another US network to see if the calls go through ok? You can manually select a network by going to Settings> Mobile Service> Network Selection> Turn off automatic.
Alex
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
26-09-2024 11:39 PM
on multiple occasions. Calling different numbers and still getting sent to
the Qantas airline booking centre... Very odd
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
27-09-2024 12:19 PM
@Isaac10
For this situation we'd recommend you contact Customer Service team on 150 from your EE handset or +44 (0)7953 966 150 from a different handset while abroad so the technical team can look into your international call routing further for you. Contact Us | Help & Support | EE
Ali
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
27-09-2024 02:33 PM - edited 27-09-2024 02:34 PM
@Isaac10 wrote:
As mentioned, it has happened on 2 devices
Are both these devices, Apple? If one is Android, it could rule out an OS-specific quirk with the dialling.
Do the numbers you're dialling, and the number you're being "redirected" to, have any commonality?
The call flow should be Local RAN > Local Core > EE Core > Destination number. Your scenario may need call traces to be obtained.
- Still waiting for replacement SIM – can't access number or request PAC in SIM cards & Porting
- Mobile number in SIM cards & Porting
- Difficulties contacting Ee in Mobile Services
- Roaming Incoming Calls outside EU in Roaming
- iv been getting calls saying ee wants to change my sim only to 5g is this real in SIM cards & Porting
