11-05-2023 03:56 PM
I set my data roaming before travelling to Menorca and I also purchased the £15 data abroad pass. I am now in my second day and all I get is not registered on network. Can't make or receive calls or texts. All my settings are correct. I have tried everything
12-05-2023 09:28 AM
If you've tried all of the suggested steps, the next one would be to speak to our Mobile Care Team, @Roulsty76.
You can find an international number to call from another phone on our get in touch help page.
Hope you get sorted.
11-05-2023 04:01 PM
Hi @Roulsty76
If you have activated roaming then it should work. Have you checked under your network settings to make sure roaming is activated?
Have you tried connecting manually to any network?
11-05-2023 05:39 PM
When you say "set my data roaming", this suggests a phone setting - and is not the important bit. Your phone needs network-level permissions to connect to foreign networks, which can only be done at EE's end - by texting ROAMING to 150 before leaving the UK, or by contacting CS if you are already abroad.
Data roaming is just a phone-setting, enabling data transfer on a foreign network that you're already connected to.
11-05-2023 08:37 PM
Done it all
11-05-2023 08:40 PM
Yes I tried that. Network unavailable it keeps saying. Movistar Vodafone and a few others. Done everything EE have asked
12-05-2023 07:32 AM
12-05-2023 09:09 AM
Pay monthly contract
12-05-2023 09:28 AM
